Hello, the visualization of the simulazione has black background. Is it possible to change it? For example setting it white
Thank you
Thank you
Thank you! I also found this command line OpenGL: changing the visualization color
Instead is It possible to change beam color (default blue) and secondary particles color (default orange) too?
yes, you can also change beam color by command lines:-
/vis/modeling/trajectories/create/drawByParticleID
/vis/modeling/trajectories/drawByParticleID-0/set e- blue
/vis/modeling/trajectories/drawByParticleID-0/set gamma red
/vis/modeling/trajectories/drawByParticleID-0/set proton yellow
and for more information about visualization you can follow the slides.
sorry i can not upload here due to forum restrictions on file size but you can download it from the attached link below:-
Hope this will solve your doubt!
priyanshu
Thank you @priyanshu-gif
I tried these command lines
#changecolor
/vis/viewer/set/background white
unfortunately it works to change the background color, but it doesn’t to change particle colors …indeed, I’ve a positron beam therefore it should have mostly e+ e- gamma secondary particles, but you see, I still have blue beam, just like the default.
moreover, there is a lot of red, …I tried to assign the red to different particles, but it it always the mostly color…
did you switch on this command line and just after this put those color change commands in vis.mac file
can you try this ?
Hello @priyanshu-gif
Yes here my vis
and also this blue is not the beam, it is the axis by default it is showing.
but you can switch off this byDraw coordinate axes:
#/vis/scene/add/axes 0 0 0 1 m
No…both the beam and the axis are blue… I see the beam creating (in blue) when I run the command line
/control/execute run1.mac
you can see here…the tube of the beam is largest than the tube of the axis
PS. One more question please, the text “5cm” moves alone when I zoom the visualization…is it possible to move it or to delete it? because I’ve the text 5cm on the axis
hello @faca87
please switch off the command
/vis/scene/add/axes 0 0 0 5 m
hello @faca87
Hello @priyanshu-gif I switched off it
now I don’t have the axes and you see…the beam is still blue.
BTW I like the blue beam…I would change the secondary particles colors.
I tried
#Change color
/vis/modeling/trajectories/drawByParticleID-0/set e+ black
/vis/modeling/trajectories/drawByParticleID-0/set e- black
/vis/modeling/trajectories/drawByParticleID-0/set gamma black
then I would have all black, but I still have same colors
Regarding of the run…here my run1.mac
run1.txt (2.0 KB)
