Visualization command not working
Please fill out the following information to help in answering your question, and also see tips for posting code snippets
Geant4 Version: 10.7.4
Operating System: Ubuntu 20
Compiler/Version: gcc 9.4.0
I have compiled in visualization according to the instructions using CMAKE and setting the variable GEANT4_USE_OPENGL_X11=ON.
Despite this I get the following:
---> I am in a smart tcsh terminal ;-) .
 Macro macros/pube_coin.mac is being run
***** COMMAND NOT FOUND </vis/scene/create> *****
*** G4Exception : UIMAN0123
Command aborted (100)
Error code : 100
Does it mean that my visualization is not compiled correctly? Or have the macro commands changed or something?
Hi, I would recommend to try running one of the Geant4 basic examples to check. If it runs correctly, then is something in your simulation. It can be related to the creation of the G4VisManager object in the main file. I would start by comparing it with the examples.
