Dear all,
I’m attempting to run exampleB1.exe in Gant 4.11.1.0 under Windows. I notice that run1.mac is working well. However, there is no visualization popping up and I am not able to see the detector. Simillarly for /vis.mac. Please see the below message. Please note I don’t use QT.
Is there anyone who use Geant4.11.1 under windows os?
Geant4 version Name: geant4-11-01 (9-December-2022)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
Registering graphics systems…
ou have successfully registered the following graphics systems.
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
Registering model factories…
ou have successfully registered the following model factories.
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
egistered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
egistered filters:
None
/vis/list" to see available colours.
ERROR: Can not open a macro file <init_vis.mac>. Set macro path with “/control/macroPath” if needed.
------- WWWW ------- G4Exception-START -------- WWWW -------
** G4Exception : UIMAN0123
ommand aborted (400)
rror code : 400
** This is just a warning message. ***
------- WWWW -------- G4Exception-END --------- WWWW -------
Candidates are: ASCIITree ATree DAWNFILE G4HepRepFile HepRepFile RayTracer VRML2FILE gMocrenFile TOOLSSG_OFFSCREEN TSG_OFFSCREEN TOOLSSG_OFFSCREEN TSG_OFFSCREEN TSG_FILE
nvoked command has failed - see above. Available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
Error code : 500
***** Illegal parameter (0) </vis/open OGL 600x600-0+0> *****
ommand aborted (500)
rror code : 500
command refused (500):“/control/execute D:\Research\Geant4\Geant4\geant4-v11.1.0\geant4-v11.1.0\examples\basic\test\B1\build\vis.mac”
