Hello Everyone,
I just installed geant4 and trying to run example B1 I got the following error message:
# Use this open statement to create an OpenGL view:
/vis/open OGL 600x600-0+0
/vis/sceneHandler/create OGL
Candidates are: ASCIITree ATree DAWNFILE G4HepRepFile HepRepFile RayTracer VRML2FILE gMocrenFile TOOLSSG_OFFSCREEN TSG_OFFSCREEN TOOLSSG_OFFSCREEN TSG_OFFSCREEN TSG_FILE
*** G4Exception : UIMAN0123
Invoked command has failed - see above. Available graphics systems are:
ASCIITree (ATree)
DAWNFILE (DAWNFILE)
G4HepRepFile (HepRepFile)
RayTracer (RayTracer)
VRML2FILE (VRML2FILE)
gMocrenFile (gMocrenFile)
Error code : 500
***** Illegal parameter (0) </vis/open OGL 600x600-0+0> *****
Command aborted (500)
Error code : 500
***** Illegal parameter (0) </control/execute vis.mac> *****
Error code : 500
just for reference, this was my cmake build command
cmake -DCMAKE_INSTALL_PREFIX=/Users/tokyo/Documents/GEANT4/geant4-v11.1.0-install cmake -DGEANT4_INSTALL_DATA=ON GEANT4_BUILD_MULTITHREADED=ON GEANT4_INSTALL_DATADIR=ON GEANT4_USE_GDML=ON GEANT4_USE_INVENTOR= ON GEANT4_USE_INVENTOR_QT=ON GEANT4_USE_OPENGL_WIN32=On GEANT4_USE_OPENGL_X11=ON /Users/tokyo/Documents/GEANT4/geant4-v11.1.0
Any suggestions on how to fix it and run the examples properly???
