I am using the following commands to avoid drawing a lot of low energy tracks:
/vis/filtering/trajectories/create/attributeFilter
/vis/filtering/trajectories/attributeFilter-0/setAttribute IMag
/vis/filtering/trajectories/attributeFilter-0/addInterval 10 MeV 100 TeV
This works nicely in a standalone application. However when using Geant4 with python I get the error message
***** COMMAND NOT FOUND </vis/filtering/trajectories/create/attributeFilter> *****
The command is in a vis.mac macro that I execute with
g4.gApplyUICommand("/control/execute vis.mac")
All other vis commands in the macro work fine, also with python. Only when these are activated I get the error…
I also tried setting these through the UI manager in BeginOfRunAction but although there is no error issued nothing happens. (running without python also this approach works fine)
That command is instantiated by the filter factory. At startup, or soon after, you should get something like the below. It seems you get this with your standalone application, but could you please check if you get it with the python interface? (I have never used the python interface myself, so this might be a question for the Python experts.)
Registered model factories:
generic
drawByAttribute
drawByCharge
drawByOriginVolume
drawByParticleID
drawByEncounteredVolume
Registered models:
None
Registered filter factories:
attributeFilter
chargeFilter
originVolumeFilter
particleFilter
encounteredVolumeFilter
Registered filters:
None
Indeed, I get those messages at startup if using the standalone application, but none appears with python interface (I used python interface just a few times, essentially adapting others code…) . I get at startup:
Geant4 version Name: geant4-10-07-patch-02 (11-June-2021)
: IEEE-TNS 53 (2006), 270-278
: NIM A 835 (2016), 186-225
WWW : http://geant4.org/
<<< Geant4 Physics List simulation engine: FTFP_BERT
OK, thanks. Let me iterate…I think this is a problem for the Python experts.
This is strange, You get
but not the other stuff. I wonder if the Python wrapper is using an old version of the vis manager…
Ah! I think I have it. It seems the g4py vis manager does not instantiate filter factories - see below. Compare this with the latest version of RegisterModelFactories in G4VisExecutive - also see below.
This is definitely an issue for the Python experts. (Perhaps you yourself can see what needs to be done?)
geant4/environments/g4py/source/visualization/pyG4VisManager.cc:
class PyG4VisManager : public G4VisManager {
virtual void RegisterModelFactories() {
RegisterModelFactory(new G4TrajectoryDrawByChargeFactory());
RegisterModelFactory(new G4TrajectoryDrawByParticleIDFactory());
Hi Bernado
You’re right there’s no specific forum for this, so this forum is probably the best. I have just escalated it to our Python expert, so let’s see what happens. Meanwhile, if you have an expertise in this direction please have a go yourself.
Hi John,
Thanks for the suggestion. Sure I can give it a try. I’m a python absolute beginner, but I understand this should be changed in the Geant4 source code, and recompile it, right ?
