I wrote a small G4 application called tiny.cc attached to this post. I compiled it with Geant4.10.7.1. When I run it I got the following warning message at the end of the run:
Run Summary
Number of events processed : 100
User=0.010000s Real=0.028433s Sys=0.010000s [Cpu=70.3%]
WARNING - Attempt to delete the physical volume store while geometry closed !
WARNING - Attempt to delete the logical volume store while geometry closed !
WARNING - Attempt to delete the solid store while geometry closed !
WARNING - Attempt to delete the region store while geometry closed !
I have to add the following line
at the end of the main function to manually open the geometry to avoid those warnings. Why didn’t the run manager automatically open the geometry at the end of a run?
Thanks, Jing
tiny.cc (3.4 KB)
CMakeLists.txt (326 Bytes)
detector.txt|attachment](upload://gR0pMsCVmhj27TWbDqTf2DeuHhy.txt) (767 Bytes)radiate.txt|attachment](upload://nhrGLd7gTC8KazrGcE80g6AMAdA.txt) (717 Bytes)
To repeat the problem, run
$ cd /path/to/tiny
$ mkdir build
$ cd build
$ ccmake ..
$ make
$ cd ..
$ G4RUN_MANAGER_TYPE=Serial ./build/tiny detector.txt radiate.txt
