What determines where an application looks for Dataset
_Geant4 Version:_v4.11.2.2
_Operating System:_Mac OS Sonoma 14.4
_Compiler/Version:_Apple clang version 15.0.0 (clang-1500.3.9.4)
_CMake Version:_cmake version 3.21.4
The application builds okay and if I run with an option like -help all is okay.
But when trying to run a simulation I get the following
<<< Geant4 Physics List simulation engine: FTFP_BERT
G4VModularPhysicsList::ReplacePhysics: G4EmStandard with type : 2 is replaced with G4EmStandard_opt4
*** G4Exception : had014
issued by : G4GammaNuclearXS::RetrieveVector(…)
Data file </opt/local/share/Geant4/Data/Geant4.10.6/G4PARTICLEXS2.1/gamma/inel93> is not opened!Check G4PARTICLEXSDATA
Now I tried using
cmake -DGEANT4_INSTALL_DATA=ON …
But I did get a warning
CMake Warning:
Manually-specified variables were not used by the project:
GEANT4_INSTALL_DATA
The I know the developer does not use CMake is there some option in CMakeLists.txt
that I need to use?
There’s an layered lookup based on builtin paths, a single environment variable and then env vars per dataset, details here: Postinstall Setup — Geant4 Installation Guide 11.2 documentation
Thanks - Now sorted.
