(geant4_env) AldairHC@MacBook-Pro build % cmake .. -DCMAKE_PREFIX_PATH=$CONDA_PREFIX -DGEANT4_BUILD_MULTITHREADED=OFF
-- The C compiler identification is AppleClang 17.0.0.17000013
-- The CXX compiler identification is AppleClang 17.0.0.17000013
-- Check for working C compiler: /usr/bin/cc - skipped
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Found EXPAT: /Users/AldairHC/miniconda3/envs/geant4_env/lib/libexpat.dylib (found suitable version “2.7.1”, minimum required is “2.2.5”)
-- Found ZLIB: /Users/AldairHC/miniconda3/envs/geant4_env/lib/libz.dylib (found suitable version “1.3.1”, minimum required is “1.3.1”)
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Found XercesC: /Users/AldairHC/miniconda3/envs/geant4_env/lib/libxerces-c.dylib (found suitable version “3.2.5”, minimum required is “3.2.5”)
-- Found Freetype: /Users/AldairHC/miniconda3/envs/geant4_env/lib/libfreetype.dylib (found suitable version “2.14.0”, minimum required is “2.13.3”)
-- Found HDF5: hdf5-shared (found version “1.14.6”)
-- Looking for H5_HAVE_THREADSAFE
-- Looking for H5_HAVE_THREADSAFE - not found
CMake Error at /Users/AldairHC/miniconda3/envs/geant4_env/lib/cmake/Geant4/G4HDF5Shim.cmake:19 (message):
Found an install of HDF5, but it was not built with support for thread
safety. Either build Geant4 in single threaded mode, or use/reinstall HDF5
with thread safety enabled. See HDF5’s install guides, available from
https://support.hdfgroup.org/HDF5/release/, for instructions on this.
/Users/AldairHC/miniconda3/envs/geant4_env/lib/cmake/Geant4/Geant4Config.cmake:330 (include)
CMakeLists.txt:11 (find_package)
