Why Are the Total Neutron Cross Sections Identical at High Energy Across Different Physics Lists in Hadr00?
_Geant4 Version: v11.2.1
_Operating System: AlmaLinux-9
_Compiler/Version: gcc (GCC) 11.4.1 20231218 (Red Hat 11.4.1-3)
_CMake Version: 3.26.4
Here’s the English translation of your text:
I am using the Hadr00 example from the extended directory of Geant4 to obtain cross section data. My goal is to get the cross section of neutrons (from 10 MeV to 1 TeV) incident on natural carbon, using different physics lists. The physics lists I am using are:
a. FTFP_BERT
b. FTFP_BERT_HP
c. FTFP_INCLXX_HP
d. QGSP_BERT_HP
However, I noticed that in the high-energy region, the cross section curves of these physics lists are identical. I’m not sure why this is the case. If anyone has experience with this, I would really appreciate your help. Thank you!
If you’d like this polished further for a forum or paper, let me know!
The following is my relevant information:
1. Contents of mac files:
Command: ./Hadr00 nc.mac FTFP_BERT_HP
#     Macro file for hadr01
#     06.06.2006 V.Ivanchneko
/control/verbose 1
/run/verbose 1
/tracking/verbose 0
/testhadr/TargetMat        G4_C
/testhadr/targetElm        C
/testhadr/TargetRadius     1  cm
/testhadr/TargetLength     1 cm
/run/printProgress         10
/testhadr/nBinsE      10000
/testhadr/minEnergy   10 MeV
/testhadr/maxEnergy   1 TeV
/run/initialize
/process/em/workerVerbose 0
/testhadr/verbose 0
/testhadr/fileName  ./output/FTFP_BERT_HP
/run/beamOn 1
2. Python script for reading cross - sections in the output root file
def extract_th1d_to_dataframe(file_path, hist_name, to_linear_energy=True, plot=False, save_csv=True, output_path="xs_output.csv"):
    Extracts data from a TH1D histogram in a ROOT file and returns a DataFrame
    containing energy and cross section values. Optionally, the data can be
    saved as a plain text file without column names or index.
    Parameters:
        file_path (str): Path to the ROOT file.
        hist_name (str): Name of the histogram (e.g., 'h2').
        to_linear_energy (bool): Whether to convert the x-axis from log10(E/MeV) to E (MeV).
        plot (bool): Whether to plot the data.
        save_csv (bool): Whether to save the data as a CSV file (only two columns: energy and cross section).
        output_path (str): Path to save the output file (default is "xs_output.csv").
    Returns:
        df (DataFrame): A DataFrame containing the energy and cross section values.
    # Open the ROOT file
    file = ROOT.TFile.Open(file_path)
    if not file or file.IsZombie():
        raise IOError(f"Failed to open file: {file_path}")
    hist = file.Get(hist_name)
    if not hist:
        raise ValueError(f"Histogram not found: {hist_name}")
    # Extract bin data
    n_bins = hist.GetNbinsX()
    x = np.array([hist.GetBinCenter(i) for i in range(1, n_bins + 1)])
    y = np.array([hist.GetBinContent(i) for i in range(1, n_bins + 1)])
    # Convert x-axis to linear energy if requested
    energy = 10 ** x if to_linear_energy else x
    # Create a DataFrame with two columns
    df = pd.DataFrame({
        "x": energy,
        "y": y
    # Plot if requested
    if plot:
        plt.figure(figsize=(8, 6))
        plt.plot(energy, y, '-', lw=1.5, label=hist.GetTitle())
        plt.xscale('log')  # Set x-axis to logarithmic scale
        plt.xlabel("E (MeV)" if to_linear_energy else "log₁₀(E / MeV)", fontsize=12)
        plt.ylabel("Cross Section (barn)", fontsize=12)
        plt.title(hist.GetTitle(), fontsize=14)
        plt.grid(True, which='both', ls='--', alpha=0.5)
        plt.legend(fontsize=10)
        plt.tight_layout()
        plt.show()
    # Save to CSV if requested
    if save_csv:
        df.to_csv(output_path, index=False, header=False)
        print(f"✅ Cross section data saved to: {output_path}")
    return df
3. Comparison of total cross-sections of different physics lists
Two reasons I can think of:
  1. There is simply no data. The data for neutron cross sections tends to get sparse as you reach beyond 15 MeV (accessible on earth with DT fusion) let alone TeV.
  2. Total cross section for a neutral particle should be proportional to the actual physical cross section of the target nucleus. The behavior at ~MeV and especially sub eV neutron energies are quantum mechanical phenomena that are generally negligible at higher and higher energies.
