I have Geant-10.07.p02. Using /process/had/rdm/analogueMC 0
as in /rdecay02
example gives me the following error:
***** COMMAND NOT FOUND </process/had/rdm/analogueMC 0> *****
*** G4Exception : UIMAN0123
Command aborted (100)
Error code : 100
I also tried /grdm/analogueMC false>
and /process/had/rdm/analogueMC false
giving me similar error. Can anyone suggest what could be wrong here?
Do you have that command before or after /run/initialize
in your macro file? commands associated with individual processes generally don’t exist (aren’t defined) until the process is instantiated, and that happens as part of /run/initialize
The code can’t tell you this in the error message, because it doesn’t (can’t!) know that the undefined command “should” exist in the future
@mkelsey : I have it after the /run/initialize
command. What could be any other possibility?
Are you sure that radioactive decay is in your physics list? An easy way to tell is to put /process/list
and see if it’s there.
@mkelsey : Yes, I do see Decay,RadioactiveDecayBase,
in the /process/list/
