Why is my custom Geant4 process triggered twice per step?
Geant4 Version: 11.2.2
Operating System: Ubuntu
Compiler/Version: 11.4.0
CMake Version: 3.22.1
I implemented a custom discrete process in Geant4 (WimpWeakInteraction). When I run a simulation, I notice that PostStepDoIt is called twice in a row for the same step:
  • The first call has a non-zero StepLength
  • The second call has StepLength = 0
Both calls change the particle’s direction and energy, which is not what I want.
I want the process to only modify the particle once per physical step.
I added a guard in PostStepDoIt:
if (steplength == 0){
aParticleChange.Initialize(track);
return &aParticleChange;}
This prevents the second call from affecting the particle, but I would still like to understand why Geant4 calls the process twice in the first place.
  • I am using a custom particle.
  • GetMeanFreePath() returns a finite value.
My question:
  • Why does Geant4 call PostStepDoIt twice?
  • What is the proper way to make my process execute only once per step?
G4VParticleChange* WimpWeakInteraction::PostStepDoIt(const G4Track& track, const G4Step& step) {
//Steplength > 0!
G4double steplength = track.GetStepLength();
/*if (steplength == 0){
return &aParticleChange;}*/
// Definiere, was nach der Wechselwirkung passiert
// Isotrope Streuung
const G4Material* material = track.GetMaterial();
const G4Element* element = Element(material);
G4double m_particle = MyCustomParticle::Definition()->GetPDGMass();
G4double Z = element->GetZ();
G4double A = element->GetA() / (g/mole);
G4double m_element = G4NucleiProperties::GetNuclearMass(A,Z);
G4double B = m_element / m_particle;
G4double alpha = ((B-1)/(B+1)) * ((B-1)/(B+1));
G4ThreeVector olddirection = track.GetMomentumDirection();
G4ThreeVector rand_vec = G4RandomDirection();
G4double cosc = 2 * G4UniformRand() - 1;
G4double theta_COM = std::acos(cosc);
G4double sinc = std::sin(theta_COM);
G4double theta_LAB = std::atan(sinc/(cosc+1/B));
G4double cosl = std::cos(theta_LAB);
G4double sinl = std::sin(theta_LAB);
G4ThreeVector rotaxis = rand_vec.cross(olddirection).unit();
G4ThreeVector newdirection = olddirection * cosl + rotaxis.cross(olddirection).unit() * sinl + rotaxis * (rotaxis * olddirection)*(1-cosl);
aParticleChange.ProposeMomentumDirection(newdirection);
// Ändere die Energie des WIMPs
G4double energy = track.GetKineticEnergy();
G4double newenergy = energy * (((1+alpha)+(1-alpha)*cosc)/2);
aParticleChange.ProposeEnergy(newenergy);
#include “physics.hh”
#include “particle.hh”
#include “interaction.hh”
MyPhysicsList::MyPhysicsList()
RegisterPhysics (new G4EmStandardPhysics());
RegisterPhysics (new G4OpticalPhysics());
RegisterPhysics (new G4DecayPhysics());
RegisterPhysics (new G4RadioactiveDecayPhysics());
void MyPhysicsList::ConstructParticle()
MyCustomParticle::Definition();
void MyPhysicsList::ConstructProcess()
AddTransportation();
G4ParticleDefinition* particle = MyCustomParticle::Definition();
G4ProcessManager* pmanager = particle->GetProcessManager();
auto weakInteraction = new WimpWeakInteraction();
pmanager->AddDiscreteProcess(weakInteraction);
MyPhysicsList::~MyPhysicsList()
What does your DetectorConstruction look like? Have you verified that the second step isn’t the particle taking a transport step out of the World geometry?
yes, I checked the particle history with verbose level 1. What I see is that my process (WimpWeakInteraction) is always triggered twice in a row at the same position.
That particle can scatter multiple times along its trajectory, but in my case the interaction always appears as pairs of two consecutive calls, where both calls change the direction and reduce the energy of the particle.
The simulation is a dark matter (WIMP) particle flying through the Earth and scattering somewhere inside the Earth material.
construction.cc (6.0 KB)
detector.cc (3.7 KB)
Thats my detector and my geometry construction, but I think the error is somewhere else. I also checked if my custom process is added two times in my physicslist…
