Why loading Physics params after beginning Run Action?
I have written a GEANT4 program to record PMT response to Cherenkov photons emitted from energetic positrons. I have initialized and registered all necessary class in my main function and just for debugging purpose, hardcoded runmanager → BeamOn(1000) in the main function. One weird thing I am noticing is the program is loading some Physics Parameters even after the beginning of Run Action and I am also running into memory issue. The output verbose is as follows:
### ===  Deexcitation model UAtomDeexcitation is activated for 1 region:
### ===  Auger flag: 1
### ===  Ignore cuts flag:   1
9.5
initialize runManager succeed
:::::::::::::::::::Batch Mode Called:::::::::::::::::
:::::::::This is the beginning of Run Action::::::::
======                 Electromagnetic Physics Parameters      ========
LPM effect enabled                                 1
Enable creation and use of sampling tables         0
Apply cuts on all EM processes                     0
Use combined TransportationWithMsc                 Disabled
Use general process                                0
Enable linear polarisation for gamma               0
Enable photoeffect sampling below K-shell          1
Enable sampling of quantum entanglement            0
X-section factor for integral approach             0.8
Min kinetic energy for tables                      100 eV
Max kinetic energy for tables                      100 TeV
Number of bins per decade of a table               7
Verbose level                                      1
Verbose level for worker thread                    0
Bremsstrahlung energy threshold above which
  primary e+- is added to the list of secondary    100 TeV
Bremsstrahlung energy threshold above which primary
  muon/hadron is added to the list of secondary    100 TeV
Lowest triplet kinetic energy                      1 MeV
Enable sampling of gamma linear polarisation       0
5D gamma conversion model type                     0
5D gamma conversion model on isolated ion          0
Livermore data directory                           epics_2017
After the beginning of Run Action, it reads the Electromag params and Radioactive params as well, although it wasn’t the case for the Geant4 example programs that I tried. What could cause this issue? I would love to have a quick response as it might give me a hint to solve the memory leak issue as well.
