_Geant4 Version:_11.1.1
_Operating System:_linux
—When using a detector to collect particle information, I do not want to create a root file, but the program cannot run without creating a root file. The specific situation is:
void muonSimRunAction::BeginOfRunAction(const G4Run *run){
G4int runID = run->GetRunID();
G4cout << “### Run " << runID << " start.” << G4endl;
G4AnalysisManager *analysisManager = G4AnalysisManager::Instance();
std::string fileName = “muonSim_” + std::to_string(runID) + “.root”;
analysisManager->OpenFile(fileName);
After deleting these few lines of program(G4AnalysisManager *analysisManager = G4AnalysisManager::Instance();
analysisManager->OpenFile(fileName)![]()
The following results have occurred:
Is there any solution to this problem
