G4VSolid* wlsSolid;
if(pVol == NULL){
if(fShape == "square"){
G4VSolid* innerSolid = new G4Box("innerSolid",length_inner,length_inner,fLength);
G4VSolid* outerSolid = new G4Box("OuterSolid",length_outer,length_outer,fLength);
wlsSolid = new G4SubtractionSolid("wlsSolid",outerSolid,innerSolid);
else if(fShape == "circle"){
wlsSolid = new G4Tubs("wlsSolid",length_inner,length_outer,fLength,0,2*pi);
else
MGLog(error) << "Incorrect shape for fiber core : "<<fShape<<" not valid! \n use square or cirlce"<<endlog;
pVol = new G4LogicalVolume(wlsSolid,G4Material::GetMaterial(this->GetMaterial()),logicalName);
This is my code snippet. When I try to compile the code, it compiles fine but it returns a warning
warning: ‘wlsSolid’ may be used uninitialized in this function [-Wmaybe-uninitialized]
I would really like to remove these warnings as there are other classes with similar code and they, too, return a warning like this.
One way I found out was to modify the snippet as follows:
if(pVol == NULL){
G4VSolid wlsSolid = new G4SubtractionSolid("wlsSolid",outerSolid,innerSolid);
G4VSolid wlsSolid = new G4Tubs("wlsSolid",length_inner,length_outer,fLength,0,2*pi);
else
Is there another(read : better/smarter) way to do it?
