Hi @Nikita,
I apologize for the delayed response. I’ve been under the weather lately and haven’t been able to get any work done. Here is some snippets of the code I’m working with:
G4int CobainEventAction::OpenFile(const G4String filename) {
G4int fROOTOutputTree = 0;
G4int fROOTOutputFile = 2;
std::cerr << "CobainEventAction::OpenFile\n";
hid_t file, space, dset, dcpl;
herr_t status;
H5D_layout_t layout;
hsize_t dims[2] = {DIM0, DIM1},
start[2],
stride[2],
count[2],
block[2];
G4int wdata[DIM0][DIM1],
rdata[DIM0][DIM1],
i, j;
// Initialize data to "1", to make it easier to see the selections.
for (i=0; i<DIM0; i++)
for (j=0; j<DIM1; j++)
wdata[i][j] = 1;
// Create a new file using the default properties.
file = H5Fcreate (filename, H5F_ACC_TRUNC, H5P_DEFAULT, H5P_DEFAULT);
std::cout << "h5file = " << file <<std::endl;
//FillData(file, space, dcpl, dset);
space = H5Screate_simple (2, dims, NULL);
std::cout << "h5 space = " << space <<std::endl;
dcpl = H5Pcreate (H5P_DATASET_CREATE);
std::cout << "h5 dcpl = " << dcpl <<std::endl;
//status = H5Pset_chunk (dcpl, 2, chunk);
dset = H5Dcreate (file, DATASET, H5T_STD_I32LE, space, H5P_DEFAULT, dcpl, H5P_DEFAULT);
status = H5Dwrite (dset, H5T_NATIVE_INT, H5S_ALL, space, H5P_DEFAULT,
wdata[0]);
std::cout << "status " << status << std::endl;
printf ("Original Data:\n");
for (i=0; i<DIM0; i++) {
printf (" [");
printf (" %3d", wdata[i][j]);
printf ("]\n");
status = H5Pclose (dcpl);
status = H5Dclose (dset);
status = H5Sclose (space);
//status = H5Fclose (file);
status = H5Funmount (file, filename);
hid_t f = H5Freopen(file);
//H5Funmount(file, filename);
if (fROOTOutputFile != 0) {
std::cerr << "closing output file\n";
if (fROOTOutputFile == 0) {
G4cerr << "Could not open HDF5 output file "<< filename << std::endl;
return 0, 0;
return file, space;
void CobainEventAction::FillData(G4int eventNumber,G4String particleName,G4double energyDeposited,G4int volume, hid_t dset)//(file, space, dcpl, dset)
hid_t file, dcpl; /* Handles */
hsize_t dims[2] = {DIM0, DIM1};
G4int wdata[DIM0][DIM1], /* Write buffer */
rdata[DIM0][DIM1], /* Read buffer */
i, j;
* Write the data to the dataset.
* Create dataspace. Setting maximum size to NULL sets the maximum
* size to be the current size.
//G4String filename = "test.h5";
std::cout << "h5 file = " << dset << std::endl;
hid_t h5f = H5Freopen(dset);
std::cout << "h5 dset = " << dset <<std::endl;
std::cout << "dims = " << dims << std::endl;
std::cout << "space = " << space << std::endl;
std::cout << "event = " << eventNumber << std:: endl;
wdata[0][0] = float(0);
wdata[0][1] = eventNumber;
wdata[0][2] = energyDeposited;
wdata[0][3] = volume;
std::cout << "wdata = " << wdata << std::endl;
printf ("\nData as read from disk by hyperslab:\n");
for (G4int i=0; i<DIM0; i++) {
printf (" [");
printf ("]\n");
wdata[0]);
I also have my entire code up on github at:
https://github.com/glicka/AdamG4
