Zero energy deposited when using GPS with Co-60 radioactive decay (G4RadioactiveDecayPhysics enabled)
Hello Geant4 community,
I am trying to simulate a Co-60 radioactive source using G4GeneralParticleSource (GPS) with true nuclear decay physics (i.e., letting Geant4 emit the gammas via G4RadioactiveDecayPhysics instead of manually shooting gammas).
However, I am consistently getting zero energy deposited for all events, even though my detector fully surrounds the source.
Simulation Setup
Geometry
  • Detector: Spherical LaBr3 shell
    • Inner radius: 5 mm
    • Outer radius: 5.5 cm
    • Centered at the origin
  • Source: Point source at origin
  • World/envelope: Air
The detector completely encloses the source.
Physics List
In main():
auto physicsList = new QBBC;
physicsList->RegisterPhysics(new G4RadioactiveDecayPhysics());
physicsList->SetVerboseLevel(1);
I also call:
G4GenericIon::Definition();
Primary Generator (GPS, no macro file)
PrimaryGeneratorAction::PrimaryGeneratorAction()
  fGPS = new G4GeneralParticleSource();
  // Position: point source at origin
  fGPS->GetCurrentSource()->GetPosDist()->SetPosDisType("Point");
  fGPS->GetCurrentSource()->GetPosDist()->SetCentreCoords(
    G4ThreeVector(0, 0, 0)
  // Angular: isotropic
  fGPS->GetCurrentSource()->GetAngDist()->SetAngDistType("iso");
  // Energy (set to zero to let radioactive decay generate gammas)
  fGPS->GetCurrentSource()->GetEneDist()->SetEnergyDisType("Mono");
  fGPS->GetCurrentSource()->GetEneDist()->SetMonoEnergy(0.0);
void PrimaryGeneratorAction::GeneratePrimaries(G4Event* event)
  // Co-60 nucleus
  auto ion = G4IonTable::GetIonTable()->GetIon(27, 60, 0. * keV);
  fGPS->SetParticleDefinition(ion);
  fGPS->GeneratePrimaryVertex(event);
Output
For all events:
Gamma 0 deposited 0 keV
Gamma 1 deposited 0 keV
Gamma 2 deposited 0 keV
Physics output confirms:
Process: RadioactiveDecay
is active for GenericIon.
What I Expect
I expect Co-60 to decay and emit 1.17 MeV and 1.33 MeV gammas, which should deposit energy in the surrounding LaBr3 detector.
Question
What am I missing in my GPS / radioactive decay setup that prevents gammas from being generated or tracked?
Is there a required setting (e.g. particle lifetime, ion time, region cuts, or GPS configuration) that I have overlooked?
*Geant4 Version:*11.4.0
Operating System: Windows
Compiler/Version: MSVC (Visual Studio 2022) – MSBuild 18.0.5
*CMake Version:*4.1.1-msvc1
Dear @Anamika_Patel
Thank you for your detailed report. It is possible that the time threshold for simulating decays might be set too low. Could you please try using a value similar to the one in the radioactive decay example? [1]
Additionally, to better understand the simulation, it may be helpful to print out the track information using /tracking/verbose 2 or to visualize the tracks directly.
Thank you for your time and efforts.
Alvaro
[1] geant4/examples/extended/radioactivedecay/rdecay01/Co60.mac at b4a16de652ec244f7a0ecc0a5cacfee21930bf75 · Geant4/geant4 · GitHub
Dear Sir,
Thank you very much for your suggestion.
I realized that the issue was indeed related to the decay time threshold. Since Co-60 has a long half-life, the nucleus was not decaying within the default simulation time window, which resulted in zero energy deposition.
After setting:
/process/had/rdm/thresholdForVeryLongDecayTime 1.0e+20 s
and enabling tracking with /tracking/verbose 2 , I was able to observe the Co-60 ion undergoing radioactive decay and the emission of the expected gamma rays (1.173 MeV and 1.332 MeV). The detector now records non-zero energy deposition correctly.
Thank you again for your guidance and support.
Anamika Patel
It is an interesting conversation/observation.
Does it mean that we can control the emissions from daughters of a decay chain by changing this parameter? and the relative emissions in a decay chain will vary with this parameter?
With Regards,
Deepak Akar
It is a global time gate. You could “gate” down to a certain daughter roughly with
/process/had/rdm/nucleusLimits A1 A2 Z1 Z2
But finer control would be to filter by the parent (such as its local time) using PreUserTrackingAction.
Thanks for clarification.
My question was specifically to the use of thresholdForVeryLongDecayTime. Will it affect the relative yields from the daughters “during simulations”?
It would only affect yields from daughters which are themselves radioactive. Since Co-60 beta decays to stable Ni-60, there’s no daughter chain to be affected (as compared to U-238, for example). The excited states of the daughter aren’t treated by RadioactiveDecay itself, but rather by Deexcitation.
yes, my intention was for decay chain involving the radioactive daughters.
Thanks
Okay, note that Geant4 does not solve the Bateman equations for secular equilibrium. When you start an event with the head of an alpha chain (U-238, Cf-252, whatever), Geant4 will decay the primary and assign it’s daughters a timestamp randomly thrown from the half-life. Then it’ll decay the daughter nucleus, and assign its daughters a timestamp from that half-life added to the parent timestamp, and so on. So you’ll get particles in your event with timestamps of millions or billions of years.
That’s what they introduced the half-life time threshold, because in terms of a detector readout, a daughter that decays in a week, a month, or a billion years is “effectively” stable.
There are event generators out there (like RadSrc or SOURCES4C), which will do secular equilibrium and give you a composite spectrum for the whole decay chain.
