Hi ![]()
While running my application in MT mode on HPC cluster, at the end of the run I get a zlib compression error and the run fails, do you know if this is a know error?
Do you have any suggestions?
Thanks in advance,
Michael
Hi ![]()
Thanks in advance,
Michael
what version of Geant4 are you running? I had the same problem on version 11.2 and it was fixed in 11.3
Yes Iām using 11.2.2, I will try to update then
Thanks a lot ![]()
For reference, what error message were you seeing?
Hi @bmorgan
this is the error message:
toolx::compress_buffer : error in zlib/deflate.
tools::wroot::directory::zip : zipper failed.
