Compiling geant4 Again
Geant4 Version:
Operating System:
I try to solve the problem when do cmake and make for geant4.11.3.2, but this is what I get.
[ 85%] Automatic MOC for target G4interfaces
[ 85%] Built target G4interfaces_autogen
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/G4interfaces_autogen/mocs_compilation.cpp.o
[ 85%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4InteractorMessenger.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4UIArrayString.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4UIcsh.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4UIterminal.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VBasicShell.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VInteractiveSession.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VInteractorManager.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4VUIshell.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/core/src/G4UItcsh.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4UIExecutive.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4UIQt.cc.o
[ 86%] Building CXX object source/CMakeFiles/G4interfaces.dir/interfaces/implementation/src/G4Qt.cc.o
[ 86%] Linking CXX shared library ../BuildProducts/lib/libG4interfaces.dylib
ld: framework ‘AGL’ not found
c++: error: linker command failed with exit code 1 (use -v to see invocation)
make[2]: *** [BuildProducts/lib/libG4interfaces.dylib] Error 1
make[1]: *** [source/CMakeFiles/G4interfaces.dir/all] Error 2
make: *** [all] Error 2
sarahabdelaziz@Sarahs-MacBook-Pro build-11.3.2 %
How can I solve this problem, please?
Already asked.being addressed in Again build Geant4
