Discontinuities in ion energy loss in helium target
Geant4 Version: 4.10.5
Operating System: RHEL9.6
Compiler/Version: gcc-11.5
CMake Version: 3.26.4
I’m running a code to look at a beam of positive ions (generally around mass A = 20) through a uniform helium target. Looking at beam energy against steps along the beam direction for any given event shows that the energy loss is discontinuous. Included below is a pdf of example plots to illustrate my point with energy in MeV and steps in mm. The second plot is zoomed in on a region of the first plot to make it easier to see the behavior. I am hoping someone can help me get continuous energy loss through the target in an efficient way.
Discontinuous-combined.pdf (130.9 KB)
G4ionIonisation* ionIoni = new G4ionIonisation();
ionIoni->SetEmModel(new G4IonParametrisedLossModel());
//ionIoni->SetStepFunction(.00001, .001*um); //First plot in pdf, These are used to best demonstrate the issue. Normal run would use .1 and 1 um.
ionIoni->SetStepFunction(.000001, .001*um);  //continuous loss, final image in pdf
Changing the step size parameters for the G4IonParametrisedLossModel in my physics list to an absurdly small number, as shown in the code snippet, achieves the desired result (final plot in the pdf). However, it is too computationally intensive. Running 5000 events takes roughly 5 minutes. Is there any way to achieve continuous energy loss while not sacrificing too much computational speed? I am currently using an older geant version (4.10.5) and would prefer to keep it that way, but will upgrade if necessary.
Thank you,
Nic
Dear @ntubaro
Thank you for your question.
Geant4 splits the energy deposition into a continuous part and discrete part, according to a threshold called “production cut” [1]. The default value is 0.7 mm for all materials, which can be translated for a very low energy threshold in case of helium (hundreds of eV probably). Please verify the value of this energy cut by enabling more verbose output using the UI command for example,
/cuts/verbose 3
You may find fully detailed explanation in this seminar [2]
Thank you for your time.
Best,
Alvaro
[1] Mean Energy Loss — Physics Reference Manual 11.4 documentation
[2] EM physics tuning in the Geant4 simulation (16 March 2021) · Indico
