Issues with matching voxel grids in physical and parallel world
I have bumped into a strange issue: In the physical world, I have a voxel grid (implemented with a G4VNestedParameterisation) with a G4VSensitiveDetector attached to it. Adding a parallel world containing a voxel grid which exactly matches the physical world voxel grid causes the G4VSensitiveDetector to give wrong results. Offsetting the parallel world voxel grid a bit fixes the problem.
Is this a known issue? Does the navigator get confused because of that?
Thanks to @allison for motivating me to look into this issue.
I filed a bug report:
https://bugzilla-geant4.kek.jp/show_bug.cgi?id=2462
in your bug report, you asked if the issue is known and has been fixed:
Thank you! It looks like we bumped into the same issue. Good to know it’s fixed.
