non-Uniform ElectricField from COMSOL
Geant4 Version: 10.07
Operating System: Window 11
Dear all,
I am trying to simulate an electric field in Geant4 that uses COMSOL output.
  • I calculated the electric field map using COMSOL with geometry like the attached images and exported them to text files.
  • I constructed my application based on the filed02 and purging_magnet examples. I wrote the application successfully. When I plotted the 3D image using QT, I saw that electric vectors concentrate at a part of the geometry as shown in the attached image. I used the following commands to plot them.
# Draw magneticfield
/vis/scene/add/magneticField
/vis/scene/activateModel Field false
#/vis/scene/add/electricField 20 fullArrow lightArrow
/vis/scene/add/electricField 50 lightArrow
Can anyone help me to solve it? Thank you in advance.
#include "ElectricFieldSetup.hh"
#include "G4SystemOfUnits.hh"
#include "G4AutoLock.hh"
namespace
    G4Mutex electricField3DLock = G4MUTEX_INITIALIZER;
ElectricFieldSetup::ElectricFieldSetup(const char* filename,
						               double xOffset, double yOffset, double zOffset)
    : fXoffset(xOffset), fYoffset(yOffset), fZoffset(zOffset),
       invertX(false), invertY(false), invertZ(false)
    double lenUnit = m;
    double fieldUnit = volt/m;
    G4cout << "\n-----------------------------------------------------------"
           << "\n      Magnetic field"
           << "\n-----------------------------------------------------------";
    G4cout << "\n ---> " "Reading the field grid from " << filename << " ... " << G4endl;
    /// This is a thread-local class and we have to avoid that all workers open the file at the same time
    G4AutoLock lock(&electricField3DLock);
    ifstream file(filename); // Open the file for reading.
    if (!file.is_open())
        G4ExceptionDescription ed;
        ed << "Could not open input file " << filename << std::endl;
        G4Exception("ElectricFieldSetup::ElectricFieldSetup", "electric001", FatalException, ed);
    // Ignore first blank line
    char buffer[256];
    file.getline(buffer, 256);
    // Read table dimensions
    file >> nx >> ny >> nz; // Note dodgy order
    G4cout << "  [ Number of values x,y,z: "
	       << nx << " " << ny << " " << nz << " ] "
	       << G4endl;
    // Set up storage space for table
    xField.resize(nx);
    yField.resize(nx);
    zField.resize(nx);
    int ix, iy, iz;
    for(ix=0; ix<nx; ix++)
        xField[ix].resize(ny);
        yField[ix].resize(ny);
        zField[ix].resize(ny);
        for (iy=0; iy<ny; iy++)
            xField[ix][iy].resize(nz);
            yField[ix][iy].resize(nz);
            zField[ix][iy].resize(nz);
    // Ignore other header information
    // The first line whose second character is '0' is considered to be the last line of the header.
    do
        file.getline(buffer,256);
    }while(buffer[1]!='0');
    // Read in the data
    double xval, yval, zval, bx, by, bz;
        for(iy=0; iy<ny; iy++)
            for (iz=0; iz<nz; iz++)
                file >> xval >> yval >> zval >> bx >> by >> bz;
                //G4cout << " xval: " << xval << " yval: " << yval << " zval: " << zval << endl;
                if( ix==0 && iy==0 && iz==0 )
                    minx = xval * lenUnit;
                    miny = yval * lenUnit;
                    minz = zval * lenUnit;
                xField[ix][iy][iz] = bx * fieldUnit;
                yField[ix][iy][iz] = by * fieldUnit;
                zField[ix][iy][iz] = bz * fieldUnit;
                // G4cout << " ix: " << ix
                //        << " iy: " << iy
                //        << " iz: " << iz
                //        << " xField: " << xField[ix][iy][iz]
                //        << " yField: " << yField[ix][iy][iz]
                //        << " zField: " << zField[ix][iy][iz]
                //        << G4endl;
    file.close();
    lock.unlock();
    maxx = xval * lenUnit;
    maxy = yval * lenUnit;
    maxz = zval * lenUnit;
    G4cout << "\n ---> ... done reading " << G4endl;
    G4cout << " ---> assumed the order:  x, y, z, Bx, By, Bz "
	       << "\n ---> Min values x,y,z: " << minx/cm << " " << miny/cm << " " << minz/cm << " cm "
	       << "\n ---> Max values x,y,z: " << maxx/cm << " " << maxy/cm << " " << maxz/cm << " cm "
	       << "\n ---> The field will be offset by " << zOffset/cm << " cm "
           << G4endl;
    // Should really check that the limits are not the wrong way around.
    if(maxx < minx) {swap(maxx,minx); invertX = true;}
    if(maxy < miny) {swap(maxy,miny); invertY = true;}
    if(maxz < minz) {swap(maxz,minz); invertZ = true;}
    G4cout << "\nAfter reordering if neccesary"
	       << "\n ---> Min values x,y,z: " << minx/mm << " " << miny/mm << " " << minz/mm << " mm "
	       << "\n ---> Max values x,y,z: " << maxx/mm << " " << maxy/mm << " " << maxz/mm << " mm ";
    dx = maxx - minx;
    dy = maxy - miny;
    dz = maxz - minz;
    G4cout << "\n ---> Dif values x,y,z (range): "
	       << dx/cm << " " << dy/cm << " " << dz/cm << " cm in z "
	       << "\n-----------------------------------------------------------" << G4endl;
void ElectricFieldSetup::GetFieldValue(const double Point[4], double* Bfield) const
    double x = Point[0] + fXoffset;;
    double y = Point[1] + fYoffset;
    double z = Point[2] + fZoffset;
    // Check that the point is within the defined region
    if (x>=minx && x<=maxx &&
       y>=miny && y<=maxy &&
       z>=minz && z<=maxz)
        // Position of given point within region, normalized to the range [0,1]
        double xfraction = (x - minx) / dx;
        double yfraction = (y - miny) / dy;
        double zfraction = (z - minz) / dz;
        if (invertX) { xfraction = 1 - xfraction;}
        if (invertY) { yfraction = 1 - yfraction;}
        if (invertZ) { zfraction = 1 - zfraction;}
        // Need addresses of these to pass to modf below. modf uses its second argument as an OUTPUT argument.
        double xdindex, ydindex, zdindex;
        // Position of the point within the cuboid defined by the nearest surrounding tabulated points
        double xlocal = ( std::modf(xfraction*(nx-1), &xdindex));
        double ylocal = ( std::modf(yfraction*(ny-1), &ydindex));
        double zlocal = ( std::modf(zfraction*(nz-1), &zdindex));
        // The indices of the nearest tabulated point whose coordinates are all less than those of the given point
        int xindex = static_cast<int>(xdindex);
        int yindex = static_cast<int>(ydindex);
        int zindex = static_cast<int>(zdindex);
        #ifdef DEBUG_INTERPOLATING_FIELD
            G4cout << "Local x,y,z: " << xlocal << " " << ylocal << " " << zlocal << G4endl;
            G4cout << "Index x,y,z: " << xindex << " " << yindex << " " << zindex << G4endl;
            double valx0z0, mulx0z0, valx1z0, mulx1z0;
            double valx0z1, mulx0z1, valx1z1, mulx1z1;
            valx0z0= table[xindex  ][0][zindex];  mulx0z0=  (1-xlocal) * (1-zlocal);
            valx1z0= table[xindex+1][0][zindex];  mulx1z0=   xlocal    * (1-zlocal);
            valx0z1= table[xindex  ][0][zindex+1]; mulx0z1= (1-xlocal) * zlocal;
            valx1z1= table[xindex+1][0][zindex+1]; mulx1z1=  xlocal    * zlocal;
        #endif
        // Full 3-dimensional version
        Bfield[0] = 0.0;
        Bfield[1] = 0.0;
        Bfield[2] = 0.0;
        Bfield[3] =
        xField[xindex  ][yindex  ][zindex  ] * (1-xlocal) * (1-ylocal) * (1-zlocal) +
        xField[xindex  ][yindex  ][zindex+1] * (1-xlocal) * (1-ylocal) *    zlocal  +
        xField[xindex  ][yindex+1][zindex  ] * (1-xlocal) *    ylocal  * (1-zlocal) +
        xField[xindex  ][yindex+1][zindex+1] * (1-xlocal) *    ylocal  *    zlocal  +
        xField[xindex+1][yindex  ][zindex  ] *    xlocal  * (1-ylocal) * (1-zlocal) +
        xField[xindex+1][yindex  ][zindex+1] *    xlocal  * (1-ylocal) *    zlocal  +
        xField[xindex+1][yindex+1][zindex  ] *    xlocal  *    ylocal  * (1-zlocal) +
        xField[xindex+1][yindex+1][zindex+1] *    xlocal  *    ylocal  *    zlocal ;
        Bfield[4] =
        yField[xindex  ][yindex  ][zindex  ] * (1-xlocal) * (1-ylocal) * (1-zlocal) +
        yField[xindex  ][yindex  ][zindex+1] * (1-xlocal) * (1-ylocal) *    zlocal  +
        yField[xindex  ][yindex+1][zindex  ] * (1-xlocal) *    ylocal  * (1-zlocal) +
        yField[xindex  ][yindex+1][zindex+1] * (1-xlocal) *    ylocal  *    zlocal  +
        yField[xindex+1][yindex  ][zindex  ] *    xlocal  * (1-ylocal) * (1-zlocal) +
        yField[xindex+1][yindex  ][zindex+1] *    xlocal  * (1-ylocal) *    zlocal  +
        yField[xindex+1][yindex+1][zindex  ] *    xlocal  *    ylocal  * (1-zlocal) +
        yField[xindex+1][yindex+1][zindex+1] *    xlocal  *    ylocal  *    zlocal ;
        Bfield[5] =
        zField[xindex  ][yindex  ][zindex  ] * (1-xlocal) * (1-ylocal) * (1-zlocal) +
        zField[xindex  ][yindex  ][zindex+1] * (1-xlocal) * (1-ylocal) *    zlocal  +
        zField[xindex  ][yindex+1][zindex  ] * (1-xlocal) *    ylocal  * (1-zlocal) +
        zField[xindex  ][yindex+1][zindex+1] * (1-xlocal) *    ylocal  *    zlocal  +
        zField[xindex+1][yindex  ][zindex  ] *    xlocal  * (1-ylocal) * (1-zlocal) +
        zField[xindex+1][yindex  ][zindex+1] *    xlocal  * (1-ylocal) *    zlocal  +
        zField[xindex+1][yindex+1][zindex  ] *    xlocal  *    ylocal  * (1-zlocal) +
        zField[xindex+1][yindex+1][zindex+1] *    xlocal  *    ylocal  *    zlocal ;
    else
        Bfield[3] = 0.0;
        Bfield[4] = 0.0;
        Bfield[5] = 0.0;
Hi
First, let me compliment you on a very nicely presented posting. And nicely set out code.
Also I see you have used debug printing - well done. (Have you tried G4debug instead of G4cout. It gets highlighted in the Qt window and easier to see.)
But are you suggesting there is a bug in the visualisation? Have you really ruled out a bug in. your code? Can you show us conclusively, for example, that your GetFieldValue produces a field where the visualisation shows nothing?
Dear John,
Thank you for your response.
  • For the first suggestion, I don’t still know how to use G4debug. Can you tell me the way to use G4Debug?
  • I will try this one as you said But are you suggesting there is a bug in the visualisation? Have you really ruled out a bug in. your code? Can you show us conclusively, for example, that your GetFieldValue produces a field where the visualisation shows nothing?
Simply replace G4cout with G4debug.
I tried to replace G4cout with G4debug. When I built the application, it showed “…‘G4debug’: undeclared identifier”
Apologies for the confusion - G4debug is only available since 11.2, and you’re using 10.7. Don’t worry about the difference, G4cout is absolutely fine.
Thank you for your information. I will try this feature with the Geant4 latest version.
Dear @allison
I have fixed the mistake. It’s due to missing zero values from the COMSOL output. This made my application read false.
Dear all,
I have some new problems. I don’t know how to fix it to unsee the warning messages.
Hi
Navigation in a field is not my area of expertise, but I would say the warnings point to more problems with your field calculation. Perhaps start with a simpler field? Or write a test program that tests it for all sensible values of position. Etc., etc.
I would recommend creating a new forum topic for this new issue, with a clear title, like “Non-physical chord lengths with COMSOL electric field.”
Dear hungbt,
I have been trying myself for 1 month now to import a simple uniform electric field from COMSOL into geant4, but when trying to visualize it, I always get an error telling me that " The field is not in this extent" and I can’t get past that. Would you mind sharing the field implementation code? how do you load the comsol output correctly into geant?
Dear @hungbt1908,
Could you please share a source code or perhaps guide on how I can add field maps inside Geant in the simplest way possible? Considering the field map fits exactly to the confined geometry (same as the spherical shape you have).
