I am having a problem with photons interacting with a piece of my geometry. I have double and tippled checked overlaps and have found none. I am confident that this is not the source of the error because it occurs at the boundary between the world volume and my copper pieces (unless I am reading the traceback incorrectly). The volume in question is a rough PCB built out of several copper pieces (each a little over 1mm thick). When investigating this problem previously I have found mention of a potential “bug” in the implication of the solid or navigator but am unsure of what steps to take to fix this problem.
Here is reference to a topic with a similar problem however his was an overlap error.
### pop requested out of 0 stacked tracks.
### 0 waiting tracks are re-classified to
0 urgent tracks and 0 waiting tracks.
NULL returned from G4StackManager.
Terminate current event processing.
G4EventManager::ProcessOneEvent()
1 vertices passed from G4Event.
Primary particle (gamma) --- Transfered with momentum (-0.0241176047083722,0.01157040153975263,-0.05314806629915705)
A new track 0x7f9f245bffe0 (trackID 1, parentID 0) is passed to G4StackManager.
1 primaries are passed from G4EventTransformer.
!!!!!!! Now start processing an event !!!!!!!
### pop requested out of 1 stacked tracks.
Track 0x7f9f245bffe0 (trackID 1, parentID 0) is passed to G4TrackingManager.
* G4Track Information: Particle = gamma, Track ID = 1, Parent ID = 0
Step# X(mm) Y(mm) Z(mm) KinE(MeV) dE(MeV) StepLeng TrackLeng NextVolume ProcName
0 0.0411 -0.00455 37.5 0.0595 0 0 0 World initStep
1 -12.6 6.05 9.7 0.0595 0 31.1 31.1 CopperPhys Transportation
2 -12.6 6.05 9.7 0.0595 0 0 31.1 World Transportation
3 -12.6 6.05 9.7 0.0595 0 0 31.1 CopperPhys Transportation
4 -12.6 6.05 9.7 0.0595 0 0 31.1 World Transportation
5 -12.6 6.05 9.7 0.0595 0 0 31.1 CopperPhys Transportation
6 -12.6 6.05 9.7 0.0595 0 0 31.1 World Transportation
7 -12.6 6.05 9.7 0.0595 0 0 31.1 CopperPhys Transportation
8 -12.6 6.05 9.7 0.0595 0 0 31.1 World Transportation
9 -12.6 6.05 9.7 0.0595 0 0 31.1 CopperPhys Transportation
10 -12.6 6.05 9.7 0.0595 0 0 31.1 World Transportation
*** G4Exception : GeomNav1002
Track stuck or not moving.
Track stuck, not moving for 10 steps
in volume -World- at point (-12.57056305372941,6.04587764860676,9.704870321532848) (local point (-12.57056305372941,6.04587764860676,9.704870321532848))
direction: (-0.4053378942583562,0.1944605300798762,-0.8932448117505387) (local direction: (-0.4053378942583562,0.1944605300798762,-0.8932448117505387)).
Potential geometry or navigation problem !
Trying pushing it of 1e-07 mm ...Potential overlap in geometry!
11 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
12 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
13 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
14 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
15 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
16 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
17 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
18 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
19 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
20 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
21 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
22 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
23 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
24 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
25 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 CopperPhys Transportation
Checking overlaps for volume CopperPhys ... OK!
*** G4Exception : GeomNav0003
Stuck Track: potential geometry or navigation problem.
Track stuck, not moving for 25 steps
in volume -CopperPhys- at point (-12.5706,6.04588,9.70487)
direction: (-0.405338,0.194461,-0.893245).
*** Event Must Be Aborted ***
G4Track (0x7f9f245bffe0) - track ID = 1, parent ID = 0
Particle type : gamma - creator process : not available
Kinetic energy : 59.5 keV - Momentum direction : (-0.405338,0.194461,-0.893245)
Step length : 1 Ang - total energy deposit : 0 eV
Pre-step point : (-12.5706,6.04588,9.70487) - Physical volume : CopperPhys (G4_Cu)
- defined by : Transportation - step status : 1
Post-step point : (-12.5706,6.04588,9.70487) - Physical volume : CopperPhys (G4_Cu)
- defined by : phot - step status : 7
*** Note: Step information might not be properly updated.
26 -12.6 6.05 9.7 0.0595 0 1e-07 31.1 World Transportation
Track (trackID 1, parentID 0) is processed with stopping code 3
