My longer term goal is to build and run the example B1 program and produce the visuals associated with that example. I attempted to do this by following the installation guide instructions. I am using Geant4 version 10 (not 100% sure what number is after the decimal point (10.3,10.4, 10.6 etc.) though It may not matter). My operating system is windows 10. The compiler and vendor version is windows visual studio 2019. My current problem that I am stuck on is when I attempt to build the example B1 executable file I get an error that a file cannot be opened. In the installation guide in section “how to make an executable file” subsection “Building ExampleB1 with CMake on Windows with Visual Studio” one of the steps says to input the following command: > cmake --build . --config Release.
This command is supposed to build the executable file for example B1 under the release sub directory, however what I get instead is this output:
%HOMEPATH%\Geant4\B1-build> cmake --build . --config Release
Microsoft ® Build Engine version 16.5.0+d4cbfca49 for .NET Framework
Copyright © Microsoft Corporation. All rights reserved.
Checking Build System
Building Custom Rule %HOMEPATH%/Geant4/geant4_10_03_p03/examples/b
asic/B1/CMakeLists.txt
exampleB1.cc
B1ActionInitialization.cc
B1DetectorConstruction.cc
B1EventAction.cc
B1PrimaryGeneratorAction.cc
B1RunAction.cc
B1SteppingAction.cc
Generating Code…
%HOMEPATH%\Geant4\geant4_10_03_p03\source\analysis\accumulables\incl
ude\G4MergeMode.hh(75): warning C4715: 'G4Accumulables::GetMergeFunction<double
': not all control paths return a value [%HOMEPATH%\Geant4\B1-build
\exampleB1.vcxproj]
LINK : fatal error LNK1181: cannot open input file ‘%HOMEPATH%\Geant
4\geant4_10_03_p03-build\BuildProducts\Release\lib\G4Tree.lib’ [%HOMEPATH%\Geant4\B1-build\exampleB1.vcxproj]
What I just described is the source of the problem however I don’t know if anything I did previously caused the error that I am now trying to fix or if I have missed a step in the process. so below is a description of what I have done already and the commands and outputs I was able to copy and paste from the command line.
After downloading visual studio, cmake and the geant4 files. I started by following the installation guide in section “building and installing” under subsection “on windows platforms” I created a build directory along side the source directory named: geant4_10_03_p03-build. Then changed to that directory then configured the build by using the following command:> cmake -DCMAKE_INSTALL_PREFIX="%HOMEPATH%\Geant4\geant4_10_06-install" “%HOMEPATH%\Geant4\geant4_10_06”
[command Copied from install guide directories maybe different but the command and structure should be almost the identical]
the output of that command came out as expected. it closely resembled the output in the install guide. Then I used the command:>cmake --build . --config Release
to have cmake run the build. I then installed the headers, libraries and support files useing the command:> cmake --build . --config Release --target install
I then moved to the other section of the guide that was mentioned earlier in this post “how to make an executable file” subsection “Building ExampleB1 with CMake on Windows with Visual Studio” (this might be a mistake on my part because i may have accidentally skipped a step in the “post-install setup” however I didn’t see anything that I obviously needed to do in order create example B1)
I have the rest of the inputs and outputs of the command line contained as I followed along the “how to make an executable file” section. Below are those commands and outputs:
c:\Program Files (x86)\Microsoft Visual Studio\2019\Community\Common7\Tools>cd %HOMEPATH%\Geant4
%HOMEPATH%\Geant4>mkdir B1-build
%HOMEPATH%\Geant4>cd %HOMEPATH%\Geant4\B1-build
%HOMEPATH%\Geant4\B1-build>cmake -DGeant4_DIR="%HOMEPATH%\Geant4\Geant4-install\lib\Geant4-G4VERSION" “%HOMEPATH%\Geant4\B1”
CMake Error: The source directory “%HOMEPATH%/Geant4/B1” does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
%HOMEPATH%\Geant4\B1-build>cmake -DGeant4_DIR="%HOMEPATH%\Geant4\Geant4-install\lib\Geant4-G4VERSION" “%HOMEPATH%\Geant4\geant4_10_03_p03\examples\basic\B1”
– Building for: Visual Studio 16 2019
– The C compiler identification is MSVC 19.25.28611.0
– The CXX compiler identification is MSVC 19.25.28611.0
– Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.25.28610/bin/Hostx64/x64/cl.exe
– Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.25.28610/bin/Hostx64/x64/cl.exe – works
– Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.25.28610/bin/Hostx64/x64/cl.exe
– Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2019/Community/VC/Tools/MSVC/14.25.28610/bin/Hostx64/x64/cl.exe – works
CMake Error at CMakeLists.txt:15 (find_package):
By not providing “FindGeant4.cmake” in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by “Geant4”, but
CMake did not find one.
Could not find a package configuration file provided by “Geant4” with any
of the following names:
Geant4Config.cmake
geant4-config.cmake
Add the installation prefix of “Geant4” to CMAKE_PREFIX_PATH or set
“Geant4_DIR” to a directory containing one of the above files. If “Geant4”
provides a separate development package or SDK, be sure it has been
installed.
– Configuring incomplete, errors occurred!
See also “%HOMEPATH%/Geant4/B1-build/CMakeFiles/CMakeOutput.log”.
%HOMEPATH%\Geant4\B1-build>cd %HOMEPATH%\Geant4
%HOMEPATH%\Geant4>find_package(Geant4)
‘find_package’ is not recognized as an internal or external command,
operable program or batch file.
%HOMEPATH%\Geant4>find_package(Geant4 REQUIRED)
%HOMEPATH%\Geant4\B1-build>cmake -DGeant4_DIR="%HOMEPATH%\Geant4\geant4_10_03_p03-build" “%HOMEPATH%\Geant4\geant4_10_03_p03\examples\basic\B1”
– Configuring done
– Generating done
– Build files have been written to: %HOMEPATH%/Geant4/B1-build
%HOMEPATH%\Geant4\B1-build>dir /B
ALL_BUILD.vcxproj
ALL_BUILD.vcxproj.filters
B1.sln
B1.vcxproj
B1.vcxproj.filters
CMakeCache.txt
CMakeFiles
cmake_install.cmake
exampleB1.in
exampleB1.out
exampleB1.vcxproj
exampleB1.vcxproj.filters
init_vis.mac
INSTALL.vcxproj
INSTALL.vcxproj.filters
run1.mac
run2.mac
vis.mac
ZERO_CHECK.vcxproj
ZERO_CHECK.vcxproj.filters
exampleB1.cc
B1EventAction.cc
B1RunAction.cc
B1SteppingAction.cc
Generating Code…
\exampleB1.vcxproj]
LINK : fatal error LNK1181: cannot open input file '%HOMEPATH%\Geant
%HOMEPATH%\Geant4\B1-build>dir/B
ALL_BUILD.vcxproj
B1.sln
B1.vcxproj
B1.vcxproj.filters
CMakeCache.txt
CMakeFiles
cmake_install.cmake
exampleB1.dir
exampleB1.in
exampleB1.out
exampleB1.vcxproj
init_vis.mac
INSTALL.vcxproj
Release
run1.mac
run2.mac
vis.mac
x64
ZERO_CHECK.vcxproj
%HOMEPATH%\Geant4\B1-build>dir /B Release
%HOMEPATH%\Geant4\B1-build>cmake --DCMAKE_INSTALL_PREFIX="%HOMEPATH%\Geant4\geant4_10_03-install" “%HOMEPATH%\Geant4\geant4_10_03_p03\examples\basic\B1”
– Configuring done
– Generating done
ALL_BUILD.vcxproj
B1.sln
B1.vcxproj
B1.vcxproj.filters
CMakeCache.txt
CMakeFiles
cmake_install.cmake
exampleB1.dir
exampleB1.in
exampleB1.out
exampleB1.vcxproj
init_vis.mac
INSTALL.vcxproj
Release
run1.mac
run2.mac
vis.mac
x64
ZERO_CHECK.vcxproj
