First, I’m sorry I can’t guarantee that I wrote the question in the right category.
I have a problem. I want to use the Cosmic-ray Shower Library (CRY) as my particle source, I think I’ve connected CRY to Geant4 correctly, but I don’t know how to use CRY to emit particles next.
I try to emit particles like GPS’s, /run/beam 10, But the following error was reported:
I don’t know how to solve the error report content “CRY library was not successfully initialized”.
When I used GPS in the past, it was direct setted up in “run.mac” so I can emit the particles I setted.
But for now, CRY is a library that simulates natural cosmic ray showers, and my understanding is that it automatically generates a source of natural particles, but how do I use it? I don’t know.
If you know any information or can provide any reference on CRY, I would be very grateful!
My English is a little weak, I hope I have described my problem clearly.Thank you very much!
I saw same error report when I tried to apply CRY library v1.7 to optical example in Geant4.
The successful method to execute this is below.
$./LXe cmd2.file
Here, cmd2file is copied from the geant folder ( /cry_v1.7/geant/cmd2.file, Edited as described below ).
Once checking its file content, Meaning of the error report is clear.
The cmd2.file call a setup.file, and it specifies the parameters in CRY ( altitude, return particles … ).
That’s requirement.
I needed to add /run/initialize statement in cmd2.file after /CRY/file setup.file statement.
The Lesson made me feel that the order of Geant4 initialization( /run/initialize) is important after CRY library initialization.
Note that Qt Window that you displayed is automatically execute /run/initialize statement.
The outline of this method is wrote in /cry_v1.7/geant/README and /cry_v1.7/doc .
Thank you very much for your reply! You showed me how to use it, and it worked!
But when I exeucuted the method below
$./LXe cmd2.file
Here is another problem. In case I missed some details, I’ve put everything that’s been run in pictures below:
u can see the problem on the last picture. **** COMAND NOT FOUND </CRY/file setup.file>***
the statements in my cmd2.file are:
/CRY//file setup.file
/run/initialize
/tracking/verbose 1
/run/beamOn 1
the statements in my setup.file are:
returnNeutrons 0
returnProtons 0
returnGammas 0
returnElectrons 0
returnMuon 1
date 7-1-2021
latitude 90.0
altitude 0
subboxlength 100
Do you have a solution to this problem?
SINCERELY YOURS!
First, there is one more slash in your statement :
A similar problem has been reported here, but no solution has been found yet. And in my program this problem is not reproduced. I don’t know the cause.
I don’t know if it’s right track, but I’ll post the main changed parts of the file that was able to cry in the /extend/optical/LXe example. The Geant4 environment uses G4VM-20.03 for VMWare distributed in a web site( https://wiki.kek.jp/display/geant4/Geant4+Virtual+Machine),
so you may easy to replicate the experiment .
file extension changed to txt.The folder structure is as follows.
/home
work – 2020 – 0404LXeCry - LXe : include , src …
└ cry_v1.7
Mac 10.13.4
MacPorts gcc9 9.3.0_1
geant4.10.05.p01
Xcode 9.3.1
I used to use the gcc in my Xcode. The project could work very well . But oneway I updated the gcc into the gcc9 and set gcc9 as my new gcc. It did’t work anymore. It seems that I did a very stupid decision
