Does not show any geometry and beam
I have the same situation this topic
Continuing the discussion from Facing issue with the OpenGL visualization software for GEANT4.:
I installed the geant4 v11.0.0 in Ubuntu (WSL2).
-DGEANT4_USE_OPENGL_X11=ON
-DGEANT4_USE_QT=ON
I build and compile examples/basic/B1. There are no errors.
Then I run ./exampleB1, Qt UI show via Xserver.
But no geometry in View.
I try /run/beamOn 1, then Qt UI dumps and Segmentation fault occurs.
log.txt (11.3 KB)
Other, I try -DGEANT4_USE_QT=OFF. UI show the geometry without beam but immediately dump.
Please advice.
Thanks.
Hi
In Facing issue with the OpenGL visualization software for GEANT4. - #7 by mritunjay the problem was solved by re-installing X11. Did you try that?
It’s also good to check that you have an up-to-date driver for your graphics card.
If you have built with
you should be able to
/vis/open OGLSX
which will open an X11 window outside the Qt GUI.
Let us know how you get on.
Thanks allison.
I tried to reinstall X11-apps, but the same situation.
I try
/vis/open OGLSX
I get a geometry on X11 window outside the Qt GUI.
But click on the X11 window, disappear the geometry in the X11 window.
I will try to check the driver of my graphics card.
I found the solution on WSL Ubuntu.
In WSL setting,
LIBGL_ALWAYS_INDIRECT=0 in /usr/share/wslu/wsl-integration.sh
In Windows Xserver(VcXsrv) setting,
Not use -wgl arguments(default is ON).
Good. Well done. Thank you for letting us all know.
