molecularDNA 11.4.2: higher DNA damage using the molecularDNA example in Geant4
I am investigating proton-induced DNA damage using the molecularDNA example in Geant4 11.4.2. I am trying to understand a discrepancy between the current public implementation and the proton result reported by Shin et al.(2021).
My environment is:
  • Geant4: 11.4.2
  • OS: Ubuntu 24.04.4 LTS on WSL
  • Compiler: g++ 13.3.0
  • Threads: 4
For a direct comparison with Shin et al.(2021)., I first used the default human_cell geometry with 50 MeV protons and 10000 primaries.
The relevant damage and chemistry parameters were:
/process/dna/e-SolvationSubType Meesungnoen2002
/process/chem/TimeStepModel IRT_syn
/scheduler/endTime 5 ns
/dnageom/radicalKillDistance 9 nm
/dnageom/interactionDirectRange 3.5 angstrom
/dnadamage/directDamageLower 5 eV
/dnadamage/directDamageUpper 37.5 eV
/dnadamage/indirectOHBaseChance 1.0
/dnadamage/indirectOHStrandChance 0.405
/dnadamage/inductionOHChance 0.0
/dnadamage/indirectHBaseChance 1.0
/dnadamage/indirectHStrandChance 0.0
/dnadamage/inductionHChance 0.0
/dnadamage/indirectEaqBaseChance 1.0
/dnadamage/indirectEaqStrandChance 0.0
/dnadamage/inductionEaqChance 0.0
/gps/particle proton
/gps/energy 50 MeV
/run/beamOn 10000
I analysed the ROOT output using the human_cell.C analysis macro provided with molecularDNA.
I tested both physics options 2 and 4 while keeping the other parameters unchanged.
For the physics option 2, the result was:
Dose absorbed : 11.067 Gy
SSB total : 226.55 Gy^-1 Gbp^-1
DSB total : 7.67344 Gy^-1 Gbp^-1
SSB/DSB : 29.5239
DSB direct : 0.719385
DSB indirect : 2.94807
DSB mixed : 0.324428
DSB hybrid : 3.68156
For physics option 4, the result was:
Dose absorbed : 11.0111 Gy
SSB total : 233.542 Gy^-1 Gbp^-1
DSB total : 9.10179 Gy^-1 Gbp^-1
SSB/DSB : 25.6589
DSB direct : 1.10583
DSB indirect : 3.55849
DSB mixed : 0.595444
DSB hybrid : 3.84203
The change from physics option 4 to option 2 reduces the DSB yield from 9.10 to 7.67 Gy Gy^-1 Gbp^-1, but the option-2 result is still higher than I expected from the 50 MeV proton results reported by Shin et al.(2021).
Shin et al.(2021) report using G4EmDNAPhysics_option2 with the ELSEPA electron elastic scattering model and G4EmDNAChemistry_option3. Their damage parameters include Rdirect = 3.5 Å, thresholds of 5–37.5 eV, POH = 40.5%, radical kill distance = 9 nm, chemistry time = 5 ns, and dtmax = 0.5 ns.
My main question is therefore whether this magnitude of DNA damage yield is considered reasonable for the current Geant4 11.4.2 molecularDNA implementation, rather than whether the 2021 result must be reproduced exactly.
I also compared the 50 MeV result with my HTB-177 and MCF-7
cancer-cell simulations.
Each geometry was analysed using its corresponding ROOT analysis
macro and geometry-specific DNA/base-pair normalisation.
The human_cell and HTB-177 simulations shown below used 10,000 primary protons, whereas the MCF-7 result used 9,000 primaries. Therefore, this comparison is based on the normalised damage yields (Gy^-1 Gbp^-1), rather than on identical numbers of primary histories or raw numbers of DNA breaks.
Geometry Physics Dose (Gy) SSB DSB SSB/DSB
human_cell p2 11.0670 226.550 7.673 29.52
human_cell p4 11.0111 233.542 9.102 25.66
HTB-177 p4 7.72783 234.035 8.98207 26.0558
MCF-7 p4 10.2164 225.934 8.303 27.21
For physics option 4, the three cell geometries therefore give normalised DSB yields of a similar magnitude, approximately 8.3–9.1 Gy^-1 Gbp^-1, despite differences in cell geometry and, for MCF-7, the number of primary histories.
I found two previous Geant4 Forum discussion that appear closely related to this issue :
In the 2022 discussion, another user reported higher SSB and DSB yields when attempting to reproduce Shin et al.(2021) proton results. The discussion noted that the `molecularDNA` example was using the newer IRT-syn chemistry implementation, and differences with the implementation used in the publication were being investigated.
A similar discrepancy was reported again in the 2023 discussion using the human_cell geometry and a closely related parameter configuration.
Because I am now using Geant4 11.4.2, I would like to understand whether this behaviour is still expected in the current implementation.
I would therefore appreciate clarification on the following points:
  1. Are SSB and DSB yields of this magnitude considered reasonable for 50 MeV proton irradiation with the current molecularDNA implementation in Geant4 11.4.2? In particular, is a DSB yield of approximately 7.67 Gy^-1 Gbp^-1 with `-p 2` and 9.10 Gy^-1 Gbp^-1 with `-p 4` within the expected range for the current implementation?
  2. The previous 2022 and 2023 Geant4 Forum discussions reported a similar tendency for molecularDNA to give higher SSB/DSB yields than the published Shin et al. results. Is this discrepancy still expected with Geant4 11.4.2, or should the current molecularDNA implementation now be able to reproduce the older published result more closely?
  3. Does the current `-p 2` configuration correspond sufficiently closely to the G4EmDNAPhysics_option2 + ELSEPA configuration used by Shin et al. (2021)? Also, should differences be expected between the current `IRT_syn` chemistry implementation and the chemistry/IRT implementation used in that publication?
  4. Using the corresponding ROOT analysis macro and DNA normalisation for each geometry, I obtain p4 DSB yields of approximately 9.10 Gy^-1 Gbp^-1 for human_cell, 8.98 Gy^-1 Gbp^-1 for HTB-177, and 8.30 Gy^-1 Gbp^-1 for MCF-7. Is this similarity in the normalised DSB yield across the three geometries reasonable for the current molecularDNA implementation under the same 50 MeV proton irradiation and damage-model parameters?
I have not modified the Geant4 or molecularDNA source code. Thank you for any clarification.
Dear,
Thank you for your interest and questions.
molecularDNA has been actively developed since 2017, with software features regularly added or removed (e.g., physics models and chemistry approaches), making it difficult to propose a single, optimized set of parameters for physics, chemistry, and early damage induction. As noted on our webpage (https://moleculardna.org), users are invited to adapt their simulation parameters to the reference data they use (e.g., DNA damage). In addition, simulation results should always be validated against experimental data when developing a new procedure.
Generally, simulated results have an uncertainty of about 20%, and experimental data are often scattered. Thus, the values you get in question 1) look reasonable (at such low LET).
Simulation parameters may change with the Geant4 version and the geometries considered (e.g., E. coli vs human cells). We recommend using the latest version of Geant4. For human cells, we currently suggest a direct radius of 2A° instead of 3.5A° (see, for example, Redirecting , Redirecting ); otherwise, you may artificially increase the number of damages. Regarding question 2), ideally, you should adjust this parameter (and other simulation parameters for physics, chemistry and early damage induction, if possible) to match your reference data (measurements, calculations, previous simulations with older versions).
Regarding 3), chemistry has been fully replaced by the optimized IRT-syn approach, which is validated independently; this is the current approach to use, as provided by default in molecularDNA.
In 4), the geometry impacts your results a bit (provided statistics are sufficient and irradiation conditions are identical), but this is less than the uncertainty in the simulation results and probably in the experimental measurements for these different cell lines (if any).
Note that regarding the choice (question 3)) of physics option (e.g., 2 or 4), G411.5 will introduce new electron physics (option 4 – 10 eV – 10 MeV) for the first time, which may also affect your simulation results. We expect other physics models in 2027. Parameter optimization will again be needed. This is not a straightforward task and will take time.
Thank you for your understanding.
